Hi
My kitchen aid is leaking by where the filter sits.
Going to replace & see if it helps.
In the event it doesn’t What should I do.
Dwinx
Hi
Dwinx
You have posted on the washer page. Your problem may be the drain pan is overflowing or the line is not going to the drain pan, so take off the lower grill/grate and shine a light in there and see if you can determine what is happening. Also check the water connection to the icemaker.
If this does not solve the problem post on the refrigerator page
