Kitchen Aid Range probe malfunction
Range continues to beep and displays a request to plug in the temperature probe. I don’t have the exact reading but I have never used the probe and I can get it to stop. The oven wont work or turn on with this message. I’ve cycled power but still get this message.
Macvean,
Your basic complaint would indicate an issue in the meat probe receptacle or wiring (usually and occasionally a control board). In most cases, disconnecting the probe wiring harness from the control, solves the issue. Of course it’s not a repair, but it’ll usually solve the issue.
We’ll need a proper model number from the production plate on the range to assit you more accurately and efficiently.
Thanks,
