I need to remove the oven door to clean the glass inside the door. How do I do that?
Grandmm,
I’ve attached the door removal and glass removal procedure from the service manual, for you.
[FONT=ArialMT][LEFT]1. Open the upper oven door.
2. Raise the two door hinge tabs to the “un[/FONT][FONT=ArialMT]locked”
position.[/LEFT]
[/FONT][FONT=ArialMT][LEFT]3. Close the oven door to within several inches,[/LEFT]
[/FONT][FONT=ArialMT][LEFT]lift and pull out on the hinges, and remove
them from the oven slots.[/LEFT]
[/FONT][FONT=ArialMT][LEFT]4. Place the oven door front side down on a
padded surface to protect the finish.
5. Remove the two screws from each of the[/LEFT]
[/FONT][FONT=ArialMT][LEFT]bottom corner glass holders and remove
the holders.[/LEFT]
[/FONT][FONT=ArialMT][LEFT]6. [/FONT][FONT=Arial-BoldMT]To remove the inner oven door glass
panels, [/FONT][FONT=ArialMT]lift each of the three glass panels,[/LEFT]
and remove them from the door.
[FONT=ArialMT][LEFT]7. [/FONT][FONT=Arial-BoldMT]To remove the door handle and outer
oven door glass:[/LEFT]
[/FONT][FONT=ArialMT][LEFT]a) Remove the three inner glass panels
(see step 6).
b) Remove the three screws from the air[/LEFT]
[/FONT][FONT=ArialMT]vent and remove the vent.
[FONT=ArialMT][LEFT]c) Remove the four door handle bracket[/LEFT]
[/FONT][FONT=ArialMT][LEFT]screws and remove the brackets and[/LEFT]
[/FONT][FONT=ArialMT][LEFT]handle from the door.
d) Slide the bottom edge of the outer oven
door glass out of the door frame and[/LEFT]
[/FONT][FONT=ArialMT]remove the glass.
Good Luck,
[/FONT][/FONT][/FONT]
MUCH easier said than done! Husband can’t even get the hinges all the way out. Have to pay repair person just so I can clean inside of front glass panel. Frustrating! ![]()
Coolintx, It can be a bit tricky, especially if there’s something damaged in the hinge assembly. You also need to keep the door assembly even and level, as you remove it from the oven or the assembly will have a tendency to “hang up” which can get frustrating.
Good Luck and Thanks,
