Kitchen Aid Mixer Speed Control
The speed control on my Kitchen Aid Stand Mixer does not lock in place. I slide the control and I have to slide it many times before it will stay in the speed I want, especially the #1 speed. Is this a spring problem or must I replace the entire lever. It will mix once I get the control to stay in place in #1 without slippiing out several times—it seems to not stop, hook in place. Thank you. Is there a shcmatic for this mixer with the speed control. I cannot find one–with speed control highlighted.
:slight_smile: :confused: [quote=wald425;606178]The speed control on my Kitchen Aid Stand Mixer does not lock in place. I slide the control and I have to slide it many times before it will stay in the speed I want, especially the #1 speed. Is this a spring problem or must I replace the entire lever. It will mix once I get the control to stay in place in #1 without slippiing out several times—it seems to not stop, hook in place. Thank you. Is there a shcmatic for this mixer with the speed control. I cannot find one–with speed control highlighted.[/quote]
