Kitchen Aid low water level
Water level seems low…when I add additional water by hand…the unit seems to work correctly.
I have checked the inlet valve and the float valve switch and both work well.
What else can I do…???
Thanks,
I took everything out…and cleaned each part…and you guessed it…it is now working…
Enjoy, Rod
