Brand: kitchen aid Model Number: KSRB25FNSS00 Fridge Main Symptom: top shelf warmer What happens & when: top shelves is 50 degrees in the fridge, next lower shelf is 45, next lower 35 and bottom two drawers are 30 degrees. The freezer is a stable 0 degrees.
what part needs to be replaced to ensure the temp. in fridge is even through-out
Are there any test I can run to better pinpoint whether the issue is the damper, damper thermistor or evaporator fan?
Other than the fact that the temperature at the top of the fridge is warmer, there is ice build up on the cabinet louver and ice build up at the bottom of the freezer.
Are there any diagnostics that you could refer me to, like a video or any guidance?
Or which part would you recommend purchasing first?
