Kitchenaid stand mixer KP26M1XMR (there is no number after the MR but it is Pro 600 in the Meringue color) I was told that the planetary for it (9708662) is discontinued but WP9708175 would work even thought it is a different color. The agitator shaft is loose and when I attach the attachments is moves up and down and when I make dough I notice what appears to be what I think is grease on it. I have noticed very fine metal specks on the base of the stand. The planetary itself seems to be stable. Would replacing the agitator shaft WP9708191 and pinion gear W11133646 solve this problem?
Brand:Kitchenaid
Model Number:Kp26m1mr5
Main Symptom:loose agitator shaft grease and metal shaving
What happens & when: mixing
