Brand:Kitchen-Aid Model Number:KDTM404KPS2 Main Symptom:Dishes not Clean What happens & when:
Error Code (if any): F7E1
Parts or tests already tried: Circulation Pump Motor Winding Resistance ~8 Ohms. Symptoms are similar to those earlier this year (in June). The original, about 2 year old pump motor winding was an open. Replaced with new pump assembly (AP6980104 (W11414076)). Whirlpool W11414076 Dishwasher Circulation Pump & Motor | Genuine OEM Part Worked fine for almost 5 months.
Recommended next steps were to check that pump and motor ass’y are not bound.
—Is there a way to do this without removing the ass’y from the dishwasher?
Check that motor is getting the proper voltage (120/60)
—Not sure how to do this with just a standard multi-meter.
—Or can the motor be fed a 120/60 supply (“manually” with temporary power supplied through the connector pins (for an audible/tactile test)
Lastly, is there a probability that the relatively early recurrence of the issue is tied to an underlying root cause, assuming my pump unit is actually still good? And if so, any ideas on what?
On your KitchenAid KDTM404KPS2, the F7E1 error code indicates a problem with the wash motor operation. It doesn’t necessarily mean the circulation pump itself has failed again.
Since your original motor winding was open and the replacement motor is now reading approximately 8 ohms, I would do some additional testing before replacing the pump assembly again. The resistance reading is encouraging, but it doesn’t rule out a mechanically bound pump or a motor that fails under load.
1. Check for a bound circulation pump
You can perform some preliminary checks without removing the entire pump assembly.
Disconnect power to the dishwasher.
Remove the lower rack and lower spray arm.
Inspect the accessible sump and pump intake areas for debris, broken glass, food particles or other obstructions.
Reassemble the dishwasher and restore power.
Start a wash cycle and listen for the circulation motor after the dishwasher finishes filling.
If you hear a humming sound but no water spraying, the motor may be mechanically bound or struggling to start.
If the motor is completely silent, I would concentrate on checking the power supply to the motor.
Unfortunately, there is no reliable way to confirm that the impeller rotates freely without gaining access to the pump itself.
2. Check the voltage going to the circulation pump
You can perform this test with a standard digital multimeter.
Safety warning: Extreme care should always be taken to protect against electric shock, which could potentially result in serious injury. Please do not live test voltage if you are uncomfortable using a multimeter around live voltage.
Remove the lower access panel.
Locate the circulation pump motor wiring connector.
Set your multimeter to AC voltage.
With the connector attached, safely back-probe the two motor supply wires using insulated test probes.
Restore power and start a wash cycle.
After the dishwasher fills, monitor the voltage when the circulation pump should be running.
Assuming the motor’s specified supply is 120 VAC, interpret the readings as follows:
Voltage reading
Possible problem
Approximately 120 VAC, motor not running
Defective or mechanically bound pump
0 VAC
Wiring harness, control board or control input issue
Voltage significantly below 120 VAC
Poor connection, damaged wiring or control board issue
120 VAC briefly, then disappears
Possible motor fault or control shutting down the motor
I would leave the motor connected during this test so you are checking the voltage under load.
I haven’t independently verified the exact motor connector pinout for this model, so confirm the supply terminals before testing.
3. Can you apply 120 VAC directly to the motor?
I would not recommend using a temporary power cord to energize the motor directly. Without confirming the motor design and electrical requirements, you could damage the motor, and running the pump without water could also cause damage.
Testing the voltage supplied by the dishwasher is a better approach.
4. What could cause the pump to fail again so soon?
Five months is certainly a short lifespan for a replacement circulation pump. I would investigate the following:
Loose or damaged wiring connections: Look for overheated terminals, corrosion or loose connections at the motor and control board.
Defective control board relay: A failing relay could cause intermittent or inadequate power delivery.
Insufficient water fill: The pump could be drawing air and operating under unfavorable conditions.
Restricted water circulation: Check for debris, excessive buildup or internal obstructions.
Water leakage: Inspect the pump motor and electrical connections for signs of moisture.
Premature replacement pump failure: Even a new OEM pump can fail prematurely.
With the power disconnected and the motor unplugged, I would also check resistance from each motor terminal to the metal motor housing, if accessible. Both should read OL.
Does the dishwasher fill with a normal amount of water?
Can you hear the circulation pump humming or attempting to start?
Does the F7E1 code return immediately or after several minutes of operation?
Are the dishes wet but dirty, or does it appear that very little water is being sprayed?
These answers, along with the voltage reading, should help us narrow down the problem without unnecessarily replacing another pump. I would also check whether the replacement pump is still covered under warranty.
