Brand:
Model Number:
Main Symptom:
Brand:
Model Number:
Main Symptom:
Model#?
Some model# helps…
How has the upper oven quit? Won’t turn on, turns on but is not heating up, etc.
jeff sr.
Kitchen aid KFGD500ESS03
Top oven igniter ( new ) will not glow
Broiler igniter will not glow ( old ) org.
Temperature probe checks out ok.
2 nd. Bottom oven works good
I plan on replacing the broiler igniter
Today. I read that the bottom oven will not work if the safety valve is at fault.
I get no error codes
If there is no voltage going to some of the igniters, the main oven control is at fault.
I got it working.
the problem to big of a hurry.
Re tracing every step. I found the most simple error.
When I twisted the wire on
One wire fell short. So actually the two wires were not twisted tight and secured. Soooo simple all is ready to go wife is baking me a double chocolate, happy cake
Thanks for the help
Thankx for the update!
jeff sr.
