My door also has no tension. Which part do I need to order. I can’t tell from the picture
I can’t find a picture using the model number but you have a spring attached to the bottom of the door on each corner which hooks to the dishwasher farther back on the frame. It could be the spring or it could be what they hook to on either end of the spring.
Thank You for you help
