Recently the door handle came apart from the screws. Am not sure how I could fix this? Do I have to replace the stainless door front? Or new screws and handle? How would I fix this, get at the screws to tighten to door handle? Or even get the parts? Any help would be great ! Thanks
Without being there I cannot be of much help.
Perhaps the following will be of some use.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%202307890.pdf
If it has custom panels then the side brackets will have to come off and the panel removed to figure out what has happened.
Sometimes the screws are covered with a trim piece (usually plastic) (see page 20 item 6).
Often pushing this up will let it ride up in the bracket to remove it.
OR
You may have to un-clip it from the bracket using a small knife.
I would start it at the bottom as you may leave a mark on it.
Once it start it should come out fairly easily.
You have been a great help. Will check it out. I saw some screws at the bottom of door panel, guess I should start there. Wish me luck, am sure I will be back
