Kitchen Aid Dishwasher
KitchenAid Diswasher starts as normal fills with heated water, but washarm doesn’t spin. Can hear motor making a humming type noise. I hit the cancel button and it will drain and can hear pump draining. All of the water drains. Is there a shaft from washarm to motor? If anybody had same problem,please contact. Thanks Al
Hi Al,
Looks like the problem is a stuck motor in the wash pump (drain pump is separate).
The first thing I would check is the chopper assembly (#6 on the break down diagram). If there is nothing wrong then the motor has to be replaced.
You can find the complete instructions in the tech sheets.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDL01ILBS0
