Kitchen Aid Dishwasher
Soap Drawer Will No Open ,this Is The Second Time It’s Failed
Repaired On Feb 2007,by Replacing Board And Drawer Assy
Any One Know The Key Seq To Test This Dishwasher !
LARRY JUSTICE
The technical data suppose to be in a pouch behind the bottom panel. You have to remove the panel and it should be on the other side. If it’s not there then you can find it here: Service Matters - Tech Sheets / Wiring Diagrams
The model number you provided is not complete, so I picked up the closest one which is KUDI02FRBL0.
Good luck.
thanks gene
for the online resource !!
larry justice
