Kitchen Aid Dishwasher won't start - has power
I have a Kitchen Aid KUD01TJBS0 dishwasher that I think is 8 years old. It won’t start.
If I push the cancel/drain button I can hear the motor run. If I push start, nothing happens. All of the lights on the control panel work with the exception of two (Heavy and High Temp Scrub).
Thanks in advance!
Jennifer
Replacement parts for WHIRLPOOL KUDM01TJBS0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
You will notice on the keypad (console) that the 3 keys that do not work all have a common connection P1-4.
Check it with a meter. Note that your negative meter lead must be on p1-4 or you will not see the switch close when you press it. This is because of the diode in the line. Try both leads as some meters do not have the negative lead actually attached to the negative side of the battery that is used to measure resistance.
You may also want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
