I cannot find info on KUDPI2CRBS1 but there is info on a KUDP02CRBS1
Please check your model number.
Below is info on the 02CRBS1 unit
Here are the parts
Replacement parts for WHIRLPOOL KUDP02CRBS1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
[COLOR=Blue]So I called in a repairman he wasn’t sure what it was but said he’d call kitchen aid. [/COLOR]
Does not sound like much of a repairman if he did not check the part that you replaced. It is possible you got a bad replacement part, unlikely but possible. If you still have the old part check the solenoid coil if it’s resistance is low or zero then this could have taken out the triac on the control board.
[COLOR=Blue]He called me next day and told me “kitchen aid said it could be the soap dish unit or the control board but that they needed to be changed together as either one could be damaging the other one if I ran the washer even once while one was malfunctioning”. [/COLOR]
I can see the dispenser damaging the control board (if it’s solenoid is shorted) but cannot see the board damaging the solenoid. You would have heard it buzzing re: the board is not giving it enough voltage so it overheats. You should be able to see overheating on the solenoid when you remove the door panel, I doubt this is the case.
Always a possibility that they have a bad batch of replacement units that have been blowing the boards when installed so have come up with this to cover their you know whats
[COLOR=Blue]He quoted me $375 [/COLOR]
He is making a nice profit on this as the both parts only come to approximately $98.00 and he would probably get them for less than that, wholesale.
[COLOR=Blue]Does this sound right? [/COLOR]
Not to me.
If this person came in, just listened to your problem and did not do any diagnosis, in my opinion you got ripped off and I would raise a stink about it as it is obvious they did not know what they were doing.
Remove power from the unit and remove the door liner.
Remove the wires from the dispenser solenoid and measure the solenoid’s coil, should be approximately 310 ohms. Also check each connector to the solenoids metal casing both should measure infinite ohms (open).
Check that the wires from the control board to the solenoid have continuity (0 ohms)
If the above are OK then it is probably just the control board that needs replacing.
