Kitchen-Aid dishwasher not cleaning dishes
Brand: Kitchen-Aid
Model Number: KDTE234GBS0
Main Symptom: Not cleaning dishes.
What happens & when: Dishwasher soap runs down the door and pool in the bottom of the dishwasher. Dishes are not cleaned. I replaced the pump and motor assembly and that did not correct the problem.
Does the dispenser seem like it opens and closes easily? Sometimes those will get gummed up or worn out and not release the detergent until too late in the cycle.
If that’s good, does it seem like the dishwasher is filling properly? Can you hear the machine switching between the upper and lower spray arms?
I’m also attaching the tech sheet for this model below, if you run the diagnostic mode as described on page 4 that’ll let you check error codes and then it will run a diagnostic test cycle. Let me know what you find.
tech-sheet-w11427956-reva (1).pdf (955.2 KB)
