kitchen aid blender mod# KSB5NK3
DAVE: HI I just ordered and rec’d today a motor and a coupling for a Kitchen Aid Blender the new motor has a different mount that holds some kind of a sensor next to the motor armature …it is a 3 wire 4 " long with white connectors on each end …one end plugs into the circuit board …the othere goes into holder ? ? ? I can’t find wire
Dave,
On the new motor, you recieved,
AP6013731
The holder for the overload protector (3 wire harness), is located on the bottom of the motor, and you “snap” the sensor end of the harness into the holder on the bottom, and then the other end onto the connector on the control board.
I think you’ll be alright from here on out.
Good Luck,
[FONT=Comic Sans MS]ACTUALLY… MY PROBLEM IS THE HOLDER THAT HOLDS THE WIRE HARNESS TO THE ARMATURE PICKUP IS DIFFERENT ON THE NEW MOTOR THAN ON THE OLD MOTOR …[/FONT]
[FONT=Comic Sans MS][/FONT]
[FONT=Comic Sans MS]DAVE SPENCER [/FONT]
[quote=davecspencer;398018]ACTUALLY… MY PROBLEM IS THE HOLDER THAT HOLDS THE WIRE HARNESS TO THE ARMATURE PICKUP IS DIFFERENT ON THE NEW MOTOR THAN ON THE OLD MOTOR …
DAVE SPENCER [/quote]
Dave,
I had a feeling, it was something else.
The sensor harness, is not available as a separate component.
In your case, it is part of the control board,
(click on part number for additional diagrams and information)
AP6013717
Thanks, and Good Luck,
