I cant get the oven to work. Top elements work fine but the coven does not work the diplay shows the fan turning. But fan in oven stays off with no heat in convection mode or regular mode. If anyone can help would be much apprieciated. Tnx
Replacement parts for WHIRLPOOL YKESA907PB00 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209761075.pdf
First I would unplug the unit for a couple hours to see if it will reset.
If no
Try running the diagnostics to see if you can get an error code from the unit.
[QUOTE=denman;81629]Here are your parts
If no
Try running the diagnostics to see if you can get an error code from the unit.[/QUOTE]
Thanks for your help Got one error code to come up it was 00 64 No letters and cannot find this code any where also a number comes up on the bottom of the display AM70 UI73 EEKEO-068 I have checked continuity on the limits that I can see. I read somewhere that they have trouble with the oven thermostat whenever there is a self cleaning done. Any help would be much appreciated thanks
Here is a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ff6fd32da573564a85256f0e0048243d/$FILE/KAELECTRANGE.pdf
It has a better description on interpreting the error codes.
Your 64 is F6 E4.
Did notice that the unit is seeuing the door as open.
