Kitchen Aid Architect KUCS03FTSS
Hi I have a 2 month old Kitchen Aid KUCS03FTSS
All of a sudden, the unit is acting funny. When I press on the foot pedal to activate a normal cycle, about 2/3rds of the way through the cycle, the unit starts to make a loud noise and compactor door starts to open from the bottom.
The door seems to slip out of its locked/closed position and the cycle stops midway. The ram is still down and the door cannot be opened any further. I then push close the door and a few minutes later, the ram lifts up and the door can be opened again.
Any idea what this could be? Might it just be a balance issue on my floor - perhaps the unit is tilted forward and needs to be rebalanced? Or is it much more complex than that?
I couldn’t find any reference to this issue in prior posts, service or tech manuals for this unit
Any help is appreciated. Thanks
I have a similar problem. Occassonally during mid cycle thew unit begins to make a loud thumping noise and I have to open the door to stop it. Once reclosed the unit resumes without the noise.
Anyone have a suggestion?
