Kitchen Aid Architect KUCS03FTSS
Hi, my Kitchen Aid used to compact by lifting up once on the toe kick (step down to open) now it no longer works unless I hold the toe kick up while the plunger compacts and retracts. Everything else is working and I can not see what needs to be done to fix it. Any ideas or suggestions would be greatly appreciated.
Thanks,
RWB
Most likely the problem is a bad motor centrifugal switch.
  • The part number for the motor switch is AP3117747
It comes with the installation instructions.
Here are the tech sheets for the Kitchen Aid trash compactor model KUCS03FTSS.
