Kitchaide kfgg500ebs3 does not get up to temperature
Brand:Kitchaide
Model kfgg500ebs3
Main Symptom:does not get to temperature
Use the attached tech sheet to place the unit into the service diagnostics mode checking for error/fault codes. Follow the fault codes to determine the issue.
tech-sheet-w11382313-reva.pdf (201.2 KB)
