Control panel on my double oven stopped working. Wondering what I need to order to repair it.
Parts for KitchenAid KEBS277DBT8 Oven - AppliancePartsPros.com
Could be a number of things you have to do some troubleshooting.
Does anything work/light up?
Check the power
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Your unit is probably hard wired so there will not be a plug
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
If power is OK check the thermal fuse (Item 19 in section 05) in the transformer circuit.
KEBS277.pdf (378.8 KB)
