Appreciate a link to or instructions on how to get at the screws in order to tighten the door handle on this oven.
Would also like to clean the window which has drip marks between the panes of glass - any tips!
By the way, this all arose because the self-cleaning function caused the Thermal Fuse (TOD) to blow - I understand this is a big problem with Kitchen Aid ovens - the accepted solution (according to many web postings) is to not use this feature!
While replacing the TOD, I thought I would address these other 2 concerns.
Many thanks!
…John
