KIRIAZI
Model: E450N/2
We’ve had this refrigerator for a long time; it used to work perfectly. But for about two years now, it hasn’t been cooling properly. When I open the lid on the bottom shelf of the refrigerator, I find that there may be ice inside the ventilation opening, so I heat the water and pour it into the ventilation opening so that the refrigerator can start working again in the correct and normal way.
But we got tired of this simple method because every time it repeats the same thing, so we repeat the same process, so I decided to bring in a refrigerator specialist.He said the problem was with the fan, so he replaced it. The refrigerator worked well for about a week, but the new fan burned out, so he replaced it again, and the same thing happened. Therefore, he decided to recharge the motor with refrigerator gas But the refrigerator is still the same, not as cold as usual, and there might even be ice in the top freezer, which is unusual and not good at all because our refrigerator is the type that uses vapor and doesn’t produce ice for cooling.
Can you analyze this fault and explain the problem to me in a clear, concise, and understandable way? How can I verify that all components are working properly? Which components are faulty? And what is the best way to repair this fault?
