Kid154
diswasher will not pump out water replaced motor pump mechanism could it be the dual pump that is no good
Remove the filter frame (#543 on the diagram), unscrew and check the piston & nut assembly (#564).
Here are the breakdown diagrams and Replacement parts for GE GSD5630D00WW | AppliancePartsPros.com
