Keypad on microwave #'s 6-0 do not work
Everything works, but all of a sudden numbers 6-0 do not work at all. Any suggestiosn?
Thanks,
JoeVee
JoeVee,
The correction is to replace the key pad (aka a membrane switch). If you need the correct part number then post the complete model number of the microwave and the color of the key pad and/or control panel.
Model number is: MH1150XM and the pad is white.
JoeVee
There suppose to be one more letter and one more digit after “M” in the model number. Look inside the microwave.
I got it from the owner’s manual, so I’ll look at the microwave. Unfortunately, I am away from home, traveling, so I should be able to respond by this saturday. Thank you for all your help.
JoeVee
Got it: MH1150XMQ4
Thanks again…
JoeVee
You are welcome. The part number for the control panel is AP3179599
Here are the break down diagrams and Replacement parts for WHIRLPOOL MH1150XMQ4 | AppliancePartsPros.com
Keep us posted.
Thanks again. I will install it as soona s it arrives and let you know the outcome. Hopefully it will resolve the issue. I assume the replacement procedure is pretty straight forward too.
JoeVee
Gene…worked perfectly, thanks a lot…
Really appreciate it very much…
JoeVee
