Keypad codes
Maytag dishwasher model #MDB8600AWB,“rinse” button only will light,flash number 9 and then go off.Is the flashing 9 a code?Will not turn on.
Replacement parts for MAYTAG MDB8600AWB | AppliancePartsPros.com
Here is a service manual and tech sheet
http://www.servicematters.com/maytag_library/docs/16021814.pdf
http://www.servicematters.com/maytag_library/docs/16026390.pdf
Run the diagnostics.
Often a flashing light indicates a stuck key.
This is usually the keypad but can be the control board.
Only way to be sure is to check the keypad with a meter (see the tech sheet)
The PDF files are almost exactly what I needed but my model MAYTAG MDB8600AWB (Quiet Series 300) Dishwasher, serial number 16450574CG, has 18 pins on the J1 jumper and I didn’t find the technical materials behind the toe panel as was stated in the manual.
Please, I was hoping you could find the proper tech pdf’s for my model/series. If you can it would help so much. I just replaced the control board last October (1 year ago) and I think the start button on the membrane is my problem this time.
Told my wife I’d spend the money to fix it one more time and if next year I have to do this again I’ll opt for a new dishwasher and a different brand. (Sorry for the rant.)
Thanks again for being there for us out here.
Eman
[quote=denman;130871]Here are your parts
There is a good STICKY at the start of this forum about it’s use.[/quote]
Here is a different tech sheet that specifically lits the MDB8600AWB
http://www.servicematters.com/maytag_library/docs/16023220.pdf
This is all that is available, well at least all I can find.
If only a couple keys are shot try the following:
Unplug the unit
Open it up
Clean the edge connector.
This sheet also only goes to 12 but I am thinking that they are only showing the points you are to test and not the other points which are not going to be tested anyway. What do you think? Thanks for replying so quickly.:wink:
Eman
[COLOR=Blue]they are only showing the points you are to test and not the other points which are not going to be tested anyway[/COLOR]
Yes,they do not show the irrelevant ones for instance the lines used to power the display.
I must admit I am a novice but would like to consider myself “handy” at times. In reading your thread I was able to fix my dishwasher problem. My dishwasher was stuck on Rinse cycle. I tried a few troubleshooting ideas with no luck. I then removed the ribbon cable from the board and cleaned it with an alcohol wipe, reconnected it, and now is working! Thanks for your ideas!!:slight_smile:
