Originally had a F4E4 error. Found hose had worked its way off the sump. Replaced the 4 hose clamps in that area and reassembled. After reassembly, received a F2E2 error, cycled the power. Now error codes now. When we start a cycle, it will drain and fill, but never runs the pump, it will eventually cancel the cycle.
Possible the diverter motor is just wet? Any chance it will dry out and work again, or just replace the diverter assy? I don’t see anything else in that area that could have been damaged by getting wet. Did I miss something?
