hi
water dispenser stopped working all of a sudden. changed filter, blew dried the water line in the fridge. what should i try next? thanks helen
Hi Helen,
There are diodes wired into the water valve harness. That makes the troubleshooting different compare to classic design. The troubleshooting instructions are attached to the post.
How to test the water fill system with diodes.pdf (554.2 KB)
How to test the water fill system with diodes - 2.pdf (144.9 KB)
