[FONT=Arial]I have a Kenmore Side by Side Refrigerator Freezer, model # 25359489990, and the water and ice maker stopped. I replaced the water filter (inside the refrigerator side, in the back near the top). I also reset the calendar setting to show the month when it was replaced. The owner’s manual mentioned two variations of this model, one with a control pad that needed to be reset after changing the filter. I have the other model, which has the slide buttons. The manual does not mention a reset button for this type. There is no water coming out of the dispenser and there is no water going to the ice maker. We have been living in this house for 18 months and the refrigerator has worked fine during that period. Is there some kind of reset button that I need to know about? What are my options? Thanks, Mike[/FONT]
Disconnect water supply line (after turning water off) and then check if you have water to the fridge, if you do then the problem is most likely at the soleniod valve. Check the filter screen at the inlet it is probably clogged.
