Kenmore washing machine top load
good morning my problem is my washing machine will not go past the rinse cycle it stops after agitating in the rinse cycle and does not drain and of course does not not go to the spin cycle. What can I do.
Hi.
If you manually advance the timer to spin does it spin?
If it does - replace the timer AP6008901
Good luck. Post the results.
Simon.
I have the same issue, I have a kenmore 600 series sm 9711916 I can move the timer around and all i get is a humming sound. I can not get it to drain the water or rinse, but i can get it to work in the water filling phase
Provide the complete model number, please.
Simon.
[quote=Simon / APP Team;745583]Provide the complete model number, please.
Simon.[/quote]
Modle 110.27612600
type 111
ser CU3422918
Hi.
Open the cabinet and check wire harness at the timer, motor and capacitor. Using the multimeter check the capacitor.
Remove the pump and try without it. There could be something jamming it.
Here is the capacitor AP6013434
The pump AP6008107
Use the video clip for the instructions.
Thank you. Post the results.
Simon.
