I am having trouble with a Kenmore washing machine model 417.43042200 Serial XC25122964 (front
loading; mechanical timer/clock. (It is on the bottom, stacked under a drier).
When the washer reaches the final spin cycle the timer stops moving and the spin continues, presumably
forever or until I manually stop it by pushing the main switch or advancing the timer manually.
At first I thought the timer was bad but the same thing happens in another wash cycle using a different section
of the timer.
My guess (with limited experience in these things) is that when the final spin cycle is reached, electric power is
suspended from the timer until some other sensor senses that the spin has achieved its purpose and it sends
power back to the timer to advance past the spin cycle and complete the wash. I think that sensor is faulty.
Any help you can offer about what that sensor would be and where I would find it (also how hard and
expensive it is to replace) would be greatly appreciated.
