Kenmore washer overflows
Occassionally, the tank fills on its own and overflows into the floor. Someone suggested the inlet water valve, and I have read the threads about cutting the power and checking the water flow. This isolates the inlet valve or the fill shut off valve. My questions is, once I do that how do I open the Kenmore Front loading Washer to replace the water inlet valve or clean and / or replace the shut off tube or sensor? I haven’t been able to find these answers for front loaders and this model 110.42934200. Thanks.
It’s pretty easy to do, once you take off the top.
Here is a service manual for your Whirlpool made Kenmore washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
[quote=sidfink43;181635]It’s pretty easy to do, once you take off the top.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf[/quote]
Thanks for the information. I hope to switch the value this weekend. I’ll let you know if that solves the problem. Thanks again.
