Kenmore Washing Machine Model 110 Series 70 . When you turn the knob to start a cycler it comes on and fills the tub with water after that it does nothing but the knobs shows it goes to the next cycle and the next and then to off. But the washer never come on. I repaired the timer and control switch and its doing the same thing nothing. i checked the lid switch. What could it be now ?HelpMeOut
Thank you for any help with this problem
[quote=HelpMeOut65;281528]Kenmore Washing Machine Model 110 Series 70 . When you turn the knob to start a cycler it comes on and fills the tub with water after that it does nothing but the knobs shows it goes to the next cycle and the next and then to off. But the washer never come on. I repaired the timer and control switch and its doing the same thing nothing. i checked the lid switch. What could it be now ?HelpMeOut
Thank you for any help with this problem[/quote]
Help Me,
Did you check the water level switch for a closed circuit, or voltage to the timer when the tub is full of water ?
A complete model number would help a lot,
