Kenmore washer issues
I replaced the Washer Temperature Switch (part #661614) - How To Replace And the Washer Water Level Switch (part #W10337780) - How To Replace which I thought would fix my problem. But now I have to turn the water feed off otherwise the water doesn’t shut off. What part might I need to check next? Thanks
Need the model number of the washer.
Eric
[QUOTE=fairbank56;868279]Need the model number of the washer.
Eric[/QUOTE]
Model number is 110 226 32100
