Kenmore washer / dryer combo (110.98752794) not heating and timer only advances on timed dry
Kenmore
Model 110.98752794
Dryer suddenly stopped heating at all, there is good air flow. Timer also does not work on air dry OR knit delicate but DOES work on timed dry. Still tumbles and blows air.
Hired a guy to diagnose the problem for $100 and he billed for a bad igniter, repair was $300 so i replaced the igniter myself but still doesnt work.
Any ideas what could be?
Test the heat first as some cycles will not advance the timer without the heat working.
Some things that can stop an gas dryer from heating…
A copy:
Q: My gas dryer runs but will not heat, what could stop my dryer from heating?
A: Things that could stop a gas dryer from heating: glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Did the igniter glow red?
jeff sr.
