I’m hoping for some guidance. I’ve searched this site (and others) but can’t find the same problem in the same model washer.
My Kenmore Front Load Washer still works great (with one exception). It appears that the bleach is not dispensing. The detergent is dispensing fine. The fabric softener is dispensing fine (although there seems to be a small amount of water that is in the fabric softener compartment after a load is complete.) But the bleach compartment stays full.
I read somewhere that these actually dispense by siphoning and if the washer is level, it can be lifted (like 1/4"-1/2") in the fromt and that will fix it. Is this possible?
I also read that something may be clogged. Can cleaner or hot water clean it out?
I’m fairly handy…was able to replace the door lock switch last year.
