Kenmore washer agitates on heavy duty but not on permanent press or normal
This is before and after new timer!
Any ideas or suggestions greatly appreciated.
M/N 11092375100
In order to provide the most accurate advise I need the complete model number of the washer.
[QUOTE=Gene;14729]In order to provide the most accurate advise I need the complete model number of the washer.
Gene.[/QUOTE]
M/N 11092375100
There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire.
[QUOTE=Gene;14746]There is a two speed motor on your washer. Most likely it does not work on the high speed due to the bad high speed motor winding, loose connection at the motor plug or a broken wire.
Gene.[/QUOTE]
Ill check it out tomorrow. With your help I know what to look for. Thanks a bunch!
Keep me updated, please.
[QUOTE=Gene;14762]Keep me updated, please.
Gene.[/QUOTE]
I will. Thanks again.
Well, I disassembled washer this morning and did not find any loose or broken wires. So I guess the motor is bad. However I did notice an electrical part (I think would be a capacitor, Part Number: AP3861916) near the motor. Could it be faulty?
Thanks,
Okey
The motor will not run at all with a bad capacitor.
