Kenmore washer 70 series
Not sure on exact model number ,but have already replaced timer.My problem was the tub fills and as it starts to agitate it starts leaking water from drain hose. I jhave elevated hose enough to know its not a siphon poblem. Sometimes when I advanced it manually I may not get the water to pump out when it should. So sometimes it acts right but most of the time it leaks water out drain hoise when its suppose to agitate. Any help I would welcome.
Is the motor running, but not agitating during the leak period?
It agitates when its suppose to on time but water leaks from hose to drain as this is agitating
If this is the old style Kenmore washer with a belt, you have something stuck in the pump. Sometimes you can take the pump apart and clean it out.
So if I decided to replace the pump I may have my problem solved? Sometimes now it seemds like it wont pump water out when its suppose to
You have lint or sting sticking the gate valve in the pump, sometimes you can dig it out with pliers.
