Kenmore washer 400
water is dripping into washer slowly even when washer is off and clothes are not getting spun out properly because of this.
Your water valve is probably leaking.
To double check this unplug the washer.
If it is still leaking then replace the valve
AP6015761
Click on the above for more info on this part.
