My daughter recieded a Kenmore Washer, not very old. when we went to hook it up it has 2 drain holes side by side. What hole do we use for the drain hose? We called around to the department store and no one seems to know. My husband is very confused.:eek: Can you help?
serial # c13001082
Kathy
i think your talking about two drain HOSES . This model is called a sud,s saver, one hose goes to the drain and the other goes to the sink basin. Just put a little water in the washer and put the 2 hoses in a bucket. watch which one the water comes out of when put in drain. You could put a[ y ] joint at the top of the single drain pipe and install the two drain hoses this won,t hurt. The washer will work.
I forgot to mention in the last post that what your to do is block the bottom hole with a cap or stopper and only use the top hole for your drain hose that,s if your not going to use the sud saver feature.
