Check the amount of detergent and water hardness.
The amount of detergent depends on the water hardness and the amount of food soil left on the dishes. Use only fresh automatic dishwashing detergent. Moist or caked detergent will not dissolve properly. Detergent should be stored in a cool, dry place. Water hardness is measured in grains per gallon. Your local water company, water softener company or county extension agent can tell you the water hardness in your area. Twelve (12) grains and higher is considered extremely hard water and detergent alone may not be enough. A water softener is recommended to improve water quality and dishwashing performance.
Note of a spray arm is missing and it is just an open hose, you may be losing so much pump pressure through it that you will not get a good wash.
It will allow you to check your heater and the high limit thermostat and the thermistor using a meter. Normally though the unit will not advance or have very long wash times if the water does not reach the required temperature.
Also I would check the water level, on most units it should fill to just below the heating element.
I am not sure about this so hopefully someone else will confirm or know for sure. If the pump starves for water poor wash results.
I am not sure about this so hopefully someone else will confirm or know for sure. If the pump starves for water poor wash results.[/quote]
Thanks, I’ve never checked a circuit before. the water is not heating up and I think it’s the heater coil at the bottom of the dishwasher We have plastic side panels. is there an easy step by step to check the circuit board. I do have a multi meter.
Easier to check at the heater/HiLimit using resistance/ohms
Remove the kick plate
Remove one wire from the heater
Measure it
Should be 10 to 35 ohms
If OK
Remove one wire from the HiLimit Thermostat
Measure it
Should be 0 ohms
Here is a little bit on meter usage
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range
Before using short the two meter leads together so you know where actual 0 ohms is.
[quote=denman;71127]Easier to check at the heater/HiLimit using resistance/ohms
Measure it
If OK
Measure it
Should be 0 ohms
There is a good STICKY at the start of this forum about it’s use.[/quote]
Thanks, I unplugged the two wires from the heating coil and get nothing. So I’ll replace the heating element. Antything else that might be the problem?
