Model: 665.14573n611
Description:
The dishwasher turns on, makes various noises. I think I hear the circulation pump going after a couple minutes, but water never goes into the tub (I waited 5 min).
What I tried so far:
Made sure the water line valve was open and water coming through the hose.
Replaced inlet valve
Checked continuity on float switch, and made sure float was working correctly (in down position).
Door must be latching because I hear dishwasher running various steps, lights on, timer counting down, etc… Normally, this dishwasher, when the door opens, pauses and makes various beeps, which it is not doing in this case.
Replaced control board.
When I cancel the wash, I can hear another motor running, so assuming drain pump is working fine.
I also replaced the circulation pump about a month ago, which fixed the issue that it wasnt washing then. -
There is no water in the tub. I know because I laid the washer on its front on the ground, so that eliminates the drain solenoid to some degree.
What else is left?
