Kenmore top freezer. Obsolete!
Brand:Kenmore
Model Number:106.72202202
Refrigerator is like new. One person household. Freezer worked fine, fridge wasn’t cooling. Most parts listed as “no longer available.” I found freezer evaporator fan not moving. Replaced. I now had a fan but didn’t fix problem. Replaced bimetal thermostat in freezer. Changed nothing. Replaced the defrost module located in refrigerator, thought it would fix, but didn’t. It was of course not OEM but fit with longer screws. May put original back in. I believe the damper could be a culprit but it doesn’t even have and electrical connection. I did find carbon on the bulb tip. How does it even work? I have more questions but will see if anyone chimes in.
Yes — on Kenmore 106.72202202, the damper can absolutely be involved even though it has no electrical connection. This is a Whirlpool-built top-mount refrigerator.
The important thing now is to stop replacing parts and check airflow.
The refrigerator section does not make its own cold. The evaporator in the freezer makes the cold, the evaporator fan moves that cold air, and the mechanical air damper regulates how much freezer air enters the refrigerator. So a freezer that is around 0°F while the refrigerator stays warm strongly points toward an airflow problem.
The “bulb” you’re seeing is likely part of a mechanical temperature-sensing system. A sealed capillary/bulb reacts to temperature and mechanically changes the damper position—so it doesn’t require wires. Don’t cut, bend sharply, sand, or puncture that bulb/capillary. What looks like carbon on its tip may just be oxidation/residue; a photo would help me identify exactly what you’re looking at.
Before buying anything else, I’d do these checks:
  1. Run the refrigerator and hold the freezer door switch closed. Confirm the new evaporator fan is actually running strongly.
  2. Put your hand at the cold-air inlet in the refrigerator compartment. You should feel a noticeable stream of freezer air while the fan is running.
  3. Move the refrigerator/freezer airflow adjustment through its full range and watch the damper door. See whether it physically opens and closes.
  4. If there’s little/no air, temporarily hold the damper fully open and reassemble enough to operate the refrigerator. If the refrigerator then starts dropping toward 35–40°F, you’ve essentially isolated the problem to the damper/air passage.
  5. Also remove the freezer’s rear inside panel and look at the evaporator frost pattern. This is important. After the compressor has run 15–30 minutes, you want a fairly even light frost across most of the evaporator—not a solid block of snow and not frost on only one little section.
Since you’ve already replaced the evaporator fan and defrost bimetal, I would put the original defrost control back in for now if you know it was operating normally. The aftermarket control adds another unknown, and a defrost control isn’t my first suspect when the freezer is maintaining temperature and the refrigerator isn’t receiving enough cold air.
Also, the bimetal itself normally won’t cause a warm refrigerator unless the evaporator is icing over. The same goes for the defrost control. If you pull that freezer panel and the evaporator has a normal frost pattern with no heavy ice accumulation, I’d move the defrost system way down the suspect list.
Your exact model does use Whirlpool evaporator fan motor 2219647 according to the parts listing, and the model’s parts documentation confirms the defrost bimetal as 2221677 (later WP4387503).
Next thing I’d like to know: freezer temperature, refrigerator temperature, and whether you feel strong, weak, or zero airflow coming into the refrigerator with the compressor and evaporator fan running. If you can also post a picture of that damper and the “carbon on the bulb tip,” I can tell you how that particular mechanism is supposed to move.
Uploading: image.jpeg…
Uploading: image.png…
My pics don’t seem to be loading. I’m unable to post pics.
The problem lies that I can’t find a replacement damper anywhere.
the manufacturer has discontinued that and most other parts for that model. They have not provided any replacement parts info
I know and that stinks.
Damper is total non electric. Bellows type. Manual. Removed it. It’s obviously the refrigerator thermostat (also obsolete) and I agree not the defrost control module. Put the old one back in the the temps are still erratics. Many refrigerator temp replacements in the wild look like the OEM part but none match except one from Canada and sketchy sources. Will continue my hunt.
