Hi, The soap door on this dishwasher will not open. I removed the inside cover and cleaned the inside of the cover and mechanism but still no luck. It seems to operate by hand by sliding the plastic rod up. I was wondering if it could be the electric controll that has the 2 plastic spring loaded arms that attach inside to operate the soap door. Any Ideas?
You will see that the dispenser is opened using a wax motor, perhaps this is shot.
Check it with a meter.
Basically it is a piston which is moved in and out by the melting/expansion of wax. If the heater inside it is open it will not run.
Hi, I tested the wax motor as you said and had 1300 ohms across the soap side and 1100 ohms across the rinse side so I am assumimg that all is ok. Any other suggestions? Thanks for your help
