Kenmore refrigerator wont cool below 45F
Brand: Kenmore
Model Number:10657022601
Main Symptom: refrigerator wont cool below 45F, Freezer OK at 0F. refrig and freezer dials set at default mid position setting.
What happens & when: Thinking this might be an ADC problem. Unpluged the refrig for 5 min to reset the auto defrost control, then moved the refrig thermostat dial to OFF, wait a bit then plugged power cord back into wall, then adj refrig thermostat back to mid-setting. Let it run for 24 hours and check the temp, refrig temp shows 45F using a refrig analog dial thermometer placed on refrig middle glass shelf. There is no ice build-up on the freezer evaporator coil and the evap fan is running normally. There is no ice blockage in the air path from the freezer to the refrig. With the freezer door closed, and refrig door open, I checked the air flow exiting the refrig upper vent– it has a weak flow. When I open the freezer door, and the refrig door is also open the air flow exiting the refrig upper air vent is much stronger. The condenser fan is spinning normally and the condenser coils have recently been vacuumed so they are relatively dust free for normal fan cooling. Compressor working normally. The only way I discovered to get the refrig temp to cool below 45F is to set the mechanical freezer damper to full-open “cold” (far left setting) and the refrig thermostat set to “coldest” {far right setting) so the compressor runs for a longer time and max freezer cold air flows into the refrig. I have not replaced any parts yet. Please give me advice how to solve this problem.
Thankyou, Ed.
The fact that the freezer temp is at 0° leads me to believe there is an airflow issue. Check to ensure the return from the fridge to the freezer has not collapsed or gotten blocked. Also, check the door gaskets for any leaks.
https://www.appliancepartspros.com/repair-help/refrigerator-repair-help/refrigerator-not-cooling.html
Hi Brad,
Thanks for your quick reply. Can you tell me what I need to do to resolve the air flow blockage inside the center wall between the freezer and the refrig? When i look at the refrig side I see a plastic vent grille adjacent to plastic drawer on the left side, I removed the grill and see molded styrafoam behind the grille with a narrow open slot. I am unable to look inside to see any blockage. Any suggestions?
If the blockage or damage is inside the wall this would not be repairable.
