Problem:
The water dispenser on my Kenmore Refrigerator is leaking. Its not a normal leak as you would think. The dispenser will operate normally but after using it, an hour later a small amount of water will drip out and then this will continue every hour. I browsed this forum and found that someone had mentioned to replace the water inlet valve, I did so and it still does the same thing. I’ve drained well over 6 gallons of water to clear any air out of the line. Anyone know what else may cause this leak to occur?
I am having same issue with my Kenmore Side by Side fridge. It stopped leaking after a while then yesterday i replaced the water filter and now after I dispense water it drips continually then stops after 5 minutes or so.
Actually, that is exactly when mine started having the issue, right after I replaced the water filter. I orginally thought maybe it was the filter and replaced it with another filter. Still no luck. Had an appliance repair shop come out and look at it and they couldn’t figure it out. Anyone know what else could cause this issue? Seems as if there is pressure building up somewhere between the filter and the valve??
I’ve got the same issue - Kenmore fridge. Never had a problem with ice or water through the door, and I change the water filter about ever 6-9 months. A couple weeks back I changed the water filter, and now I’ve got a periodic, slow drip from the water dispenser. Sometimes it slows down or stops altogether, but it’s sort of random. Usually it will drip a bit after using the water dispenser, and then stop. Sometimes it will drip slowly for a bit, then quickly for a time, and then stop. I took the filter out and reinstalled it but that didn’t seem to help.
