[quote=Joe / APP Team;443921]RL,
Thanks for the model number, the missing number narrowed it down to 10 possilities.
As best I am able to determine, your prolem would be in the control board, unless you have a low voltage problem to the refrigerator.
This control board assembly is common to all versions of the particular fridge and should work for your unit.
AP6007324
It’s located in the control panel of the refrigerator section, here are some basic instructions,
1. [FONT=Arial][SIZE=3]
[LEFT][/SIZE][/FONT]Unplug refrigerator or disconnect power.
2.
[/LEFT]
[LEFT][/SIZE][/FONT]Remove the mounting screws and drop the control panel.
3.
[/LEFT]
[FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]
[LEFT][/SIZE][/FONT]Press against the plastic retaining clips to release the main portion of the board from the control box. Then release the narrow portion of the board.
4.
[/LEFT]
[LEFT][/SIZE][/FONT]Disconnect the wire connectors and carefully remove the board from the control panel.
5.
[/LEFT]
[LEFT][/SIZE][/FONT]Remove the new control board from the electrostatic packaging. Carefully, bend the front of the board up until the tabs between the circuit boards separate. The boards will remain connected by trace wires. Be careful not to damage components on the topside of the board.
6.
[/LEFT]
[LEFT][/SIZE][/FONT]Position the tabs from the front of the board under the edge of the main board until it is bent to about a 40° angle.
7.
[/LEFT]
[LEFT][/SIZE][/FONT]Reconnect the wiring connectors to the new board.
8.
[/LEFT]
[LEFT][/SIZE][/FONT]Install the new board under plastic retaining clips on the control box.
9.
[/LEFT]
[LEFT][/SIZE][/FONT]Replace the control panel.
10. Plug in refrigerator or reconnect power.[/LEFT]
[LEFT]Good Luck,
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
[/quote]
Thanks, I will order the part from APP
