I know this problem has been posted a lot, but I can’t find a post that talks about my specific problems. So, any help would be appreciated.
I have a Kenmore that is about 3 years old. For over a year at least, it has not been working correctly. The fridge is always approx. 45-50 degrees. Sometimes, it is warmer. The milk usually goes bad after 4 or 5 days.
In the freezer, you can tell that things freeze and then defrost. When I take out a tv dinner for example, the cardboard box seems almost wet and mushy. There is about half an inch of frost on some of the other boxes in there. Also, on the right side of the freezer, there is a forzen puddle of water that goes from the back panel to the freezer door. The coils behind the plastic panel inside the freezer are not iced over, BUT the fan freezes over and there is also ice all inside that plastic panel.
I have had a technician come out 3 times, from 2 different repair companies. The only thing that they do is take the panel off and defrost everything with a heat gun. I have also had to do this about 3 times myself due to the fan icing over.
Mike
