Kenmore Pro 40140483800 freezer not keeping consistent temp
Brand: Kenmore Pro (built by Samsung)
Model Number: 40140483800
Main Symptom: Freezer Temp not consistent
What happens & when: a couple of times a day freezer temp goes from set point of 0F up to a different temp (sometimes 5-10F, sometimes 20F). Typically it goes back to 0F on its own.
Error Code (if any): none showing with built-in diagnostics
Parts or tests already tried: nothing yet. Fully defrosted it, didn’t change the behavior
The refrigerator seems a-ok throughout all of this, keeping a consistent temp on set point (38F). The freezer is usually achieving set point (0F) but a couple of times a day I’ll see it jump to a higher temp (without the door being opened, no new food) or any other changes. Sometimes close to 32F, sometimes 5-10F. I disassembled the rear of the freezer side (from the inside), didn’t see any frost buildup or anything else obviously out of whack. Let it fully defrost for a number of house anyway, got it back to together, and it’s still doing the same behavior.
Is it a good first move to replace the freezer thermostat? I believe I saw that when I had the back panel off. It seems to be DA32-10105X Refrigerator Defrost Thermostat | Genuine Samsung OEM In Stock and the cheapest option before moving on to the more expensive parts?
Thanks in advance!
Hi Jeff3,
It sounds like the defrost system is operating properly, so a defrost thermostat likely wouldn’t be needed in this case.
To better understand what’s going on, how is the temperature being measured?
  • Is it coming from the appliance display,
  • Or are you using a separate thermometer, such as a Bluetooth or standalone unit?
Hi William, thanks for the response. I’m seeing the temperature on the on-door display. There’s an analog and a digital gauge. I don’t know if there being fed by the same thermostat
I will say the freezer is warming up; the ice cream gets soft.
Thanks for your continued help!
Jeff
There is a way to test the freezer thermistor from the main control to help determine whether the issue is with the thermistor itself or the control board.
If possible, place a digital thermometer inside the freezer. A wired probe thermometer or wireless temperature reader works best so you can monitor the temperature without opening the door.
To perform the test:
  1. Remove the front top panel of the appliance.
  2. Turn the power switch to the OFF position and verify power is off (the dispenser display should go blank).
  3. Locate the transformer and main control on the right side of the machine compartment and carefully dismount them from the wall.
  4. Find connector CN30, which has a 6-wire connection, and disconnect it.
With the connector unplugged:
  1. Using a multimeter set to Ohms, test resistance between the white wire with black stripe and the gray wire.
:backhand_index_pointing_right: What resistance reading do you get?
:backhand_index_pointing_right: And what was the freezer temperature at the time of the test?
These two pieces of information will help determine if the thermistor is reading correctly or if the issue is more likely with the control. Once the test is complete, you can reassemble the unit and restore power.
Let us know your readings and temperature, and we’ll help interpret the results.
Thank you William, I’ll respond back Friday. I now have a wireless thermometer in both the refrigerator and freezer sections , and although I don’t know their accuracy it will at least be a second opinion from the built in ones.
I’m borrowing a multimeter Friday morning, so I’ll post the resistance value (and temperature measurements) Friday. Thanks!
Hi, maybe I’ve made some progress. The built in displays show 5f and 38f, whereas a dual remote sensor shows 11/39. Opening up the top, I only see connectors CN 1-8, no CN30. Am I looking in the wrong place?
One more adjacent nugget of information. It does seem that if the temperature is sitting higher than expected, turning the power off for a while (such as to get to the picture included) and powering it back on typically changes something such that the temperature(s) quickly make it back to their settings (ie 0F / 38f ). Is this useful information at this point?
CN2 is 6 wires, and has a grey and white/black, which seems to measure 23 kohm when the freezer reads roughly 10f. I got 23 k ohm consistently with a few tests, although it is tricky for me to test as the molex connector “holes” are incredibly small and I had to improvise (ie sticking 2 tiny nails into those pin openings, then testing impedance from there. I’m also
attaching a pic of that harness connected to CN2 in case that’s the one for my fridge.
Does this mean anything to you? If so, let me know what you think and what the next steps are.
Thank you, Jeff
The connection CN2 on the terminal block leads to CN30 on the control and works for testing. The sensor measuring at 23K Ohms identifies the thermistor is reading around 9 degrees which would be within tolerance of what the actual temperature is. As the sensor is measuring within tolerance, and with the temperatures correcting after a hard reset, the failure would very likely be with the main control board. This link can be used to view the control part information. DA92-00248B Refrigerator Main Control Board | Genuine Samsung OEM In Stock
Thank you !
Are you aware of any directions available to replace the part? Or is it simply behind the “board of connectors” in my picture and can be replaced without removing the unit from the installed location?
Thanks for the diagnosis !
For the replacement, I would suggest cutting power off at the breaker. The only information I can readily find is “After removing the transformer, pull out the housing connected to the terminal block, remove 2 screws, remove ground wire, and finally pull out PCB-Housing Cover. After opening the PCB-Housing Cover, pull out the housing and remove 4 screws to remove the SMPS. Remove the Main PCB from the PCB-Housing.” Based on what I see by looking at a picture the housing, the transformer cover on the right, the transformer control, and the terminal block plate would need to be removed. Removing the terminal block plate should expose two screws on the left side (screw ports circled in attached image). There may be a screw at the top left (circled in red) that may need to be removed. Once all the screws have been removed, it looks like the housing should rotate down from the top, and then lift up and out.
Thanks for your insight, I appreciate alL of your help getting this far! I’ll get the replacement board ordered, and report back here on my hopeful victory!
Hello, unfortunately I’m picking this back up - this is in a new-to-us-house that we’re slowly fixing up and moving into.
While I had some optimism that the new board would be the fix, it was not to be. I wanted to believe that the maximum highs weren’t as bad and that we may be able to live with it, but this last week as we’ve been living here full time the temperature swings are large. I’m attaching the output graph of a 3rd party thermometer over the last week to show the swings. The refrigerator side varies also, but not nearly as extreme - between 41 and 47 over the same time period. This is with the thermostats set for 0 and 38F respectively.
What could I try next, now that the main board has been replaced such that it can be assuringly ruled out?
Thanks in advance!
Does the compressor seem like it is operating almost non-stop until about 8 hours or so of compressor run time?
It has seemingly been running consistently since first thing this morning when I read your message (so maybe 4+ hours?)
Was there a spike in temperature that may have occurred overnight? It may be possible the appliance is struggling to get down to temperature after a defrost cycle.
The biggest spike was at 7pm (up to 26F) recently and looking back over the last days the spikes don’t seem to align on any 24hour cadence (mostly random). We actually weren’t home around that time of 7pm, so no new food went in, door opened for a long, change in environmental temp/humidity, nothing that’s not steady state.
I’m thinking things are pointing towards the compressor, which is no longer available unfortunately.
If you access the compressor section, does the condenser fan seem to circulate air fairly well? Also, at the bottom of the appliance, there will be a sealed system heat loop in the drain tray behind the kickplate. Does it look like it has corrosion or any spots that might have a pin hole in it?
Update. it is the compressor. Neither I, nor the local built-in repair man, can find a suitable replacement compressor. Everyone in my semi-rural area is against trying to plumb in an appropriate but different one, as the cost and risk of not having it go well would be quite high considering this is 18 years old. Thanks everyone for the help, Sub Zero here we come!
